Old Mar 15, 2009 | 04:37 PM
Bulldogger's Avatar
Bulldogger
Default Re: Negative DA this weekend and stiil no new pulley!!!!!!!!!
Originally Posted by cruzinquick
It's your cold air and closer to negative DA that bringing up your AFR's. This summer in 70 degree weather you should be back in the 11-12 AFR range. If not something is up. I went up the mid to high 12 AFR's when I ran at Famoso. I usually never hit 12's when I run in AZ. I would assume I'd creep into the 13's if I was in similiar conditions as ATCO. The ECU adjusts for thin air and increase's AFR's. It must be looking at (IAT's?) another parameter that's still reading fine, and not protecting from high AFR's.
Yeah, I figured it was outside temp related but wanted to just make sure, I am just trying to decide if I should go with TVT injectors or a Kenne Bell Boost-a-pump. I would rather do the injectors but I am unsure if they will fit with the plenums in place. they are a 1/2" taller. As of right now car has delayed shift from 4th-5th probably due to lean condition and pulling timing.
