Old Mar 15, 2009 | 06:28 PM
blackcrossfire07's Avatar
blackcrossfire07
Default Re: Water Drops--- Can Window Be Adjusted?
Some glass was not set correctly to the proper glass/seal specs and there was a TSB on this matter. I do not trust the shops too much and I was going to do mine myself. I do not get water inside but I am told it has the wind whistling through it and I can see that the fit is not as good as the driver side. The shop manual explains the method.
As far as I know, the wind is not whistling through my passenger window. At least I can't hear it sitting in the driver side.
I massaged the rubber pieces around the window yesterday. I just washed my car and sprayed around the window. Got it nice and wet without spraying it hard with pressure. No water drops. I am going to keep an eye on it. If it ever starts leaking, at least I know the window angle needs to be adjusted.
