Old Mar 15, 2009 | 10:23 PM
SRTpowa's Avatar
SRTpowa
Default Re: Negative DA this weekend and stiil no new pulley!!!!!!!!!
Originally Posted by cruzinquick
I was thinking the same thing. I don't recall ever having the opportunity so far to be WOT from 4th to 5th. So I can't say if I have that delay.
MikeR-- Sounds like your coldest air is behind you. You should be dialed in for summer fun.
SRTPowa-- I say get a solid baseline in the best weather you can drive to. Then go for the pulley and try to solve the puzzle. I say stacked pulleys if working properly should be good for 11's in any DA of 3600' or better.
This is probally the best weather right now. Soon it will be 80-100 with 98% humidity and the AF will most likely drop but then my concern will be IAT. So that is my interest in the meth injection because it solves both problems. Guess I can look forward to some experimenting.
