Old Mar 16, 2009 | 07:18 AM
LantanaTX's Avatar
LantanaTX
Default Re: Turbo vs SC Comparison
Originally Posted by REVIT93RX7
IAT's are the key to running better. The cooler air is more dense and can create a bigger volume in the combustion chamber. So that is a hard question to answer. There are various IC options for Turbo and not so many options for our water to air IC in our car.
Like he said, the colder the better for each system. When you compress air it gets hot. I think roots type blowers heat soak more than a turbo becuase they are usually mounted right on the engine. There are other differences as well between how they perform. A roots type blower (like on the SRT) give great power and torque from idle up and feel like you have a larger engine under the hood. Turbos and centrifigul super chagers (like Votec) can give better top end preformance and can usually show higher HP numbers. For normal street driving I prefer a super charger since it is instant and works better in the lower RPM range and produces better low end torque. To get the best of both worlds I have seen people twin charge their engines with a roots style s/c and turbo or two turbos of different sizes.
