Old Mar 16, 2009 | 05:29 PM
loungn14's Avatar
loungn14
Default Re: How do you remove the crank bolt?
Originally Posted by ProjectMayhem
Well i let mine cool down all the way broke loose way easier then i thought it would. rechecked it and it seems good no problems yet. I'll keep checking it after evey hard run but i dont think its going anywhere.
Your right, it won't be going anywhere. What happens is that the stretch bolt already being stretched moves a hair. This causes the crank pulley to spin out of balance and....YIKES. Think of it this way. When you get our tires done, they put small pieces to balance out the wheel under 1600 rpm. Now, a little out of balance on something that is spinning at 6000 rpm.....not good.
