Old Mar 16, 2009 | 08:27 PM
Josh@HoPRacing's Avatar
Josh@HoPRacing
Default Re: Everything you need to know about Methanol Injection
Originally Posted by BlUEMDsrt6
Hey man, do you think it would be a good idea to get rid of the small intercooler and get a pipe fabbed up with alcohol injectors installed before the iat sensor to bring the air from the sc to the manifolds?
The heat exchanger which is located in front of the car just behind the bumper is actually really good from the factory, holds about 2 pints more coolant than some aftermarket replacements that claim to be better. I'm assuming this is what you are calling the intercooler. The intercooler itself which is below the supercharger is made from garrett I believe, I looked at doing a custom intercooler replacing the factory core stlye and going to laminova cores. Problem I had was the length of the cores and the room for the intercooler was insufficient. Never should anything be admitted into the engine before the sensor, always inject after. Basically it all boils down to :
IAT=Octane. The higher the temps the higher the octane.
