Re: Hi to all...
Reply from Vancouver BC Tool for the top is 187.00 from Chrysler, called Multi Function part # 5140795AA
I purchase my ROADSTER, NOT RAGTOP in California. For technicality your car should have VIN #1 for first number USA Built, BUT it was all made in Europe and seems some assembly in USA to get made in USA label. Maybe only body put on in USA. Could be # 2 I do not know what Canada code is but probably same situation.
Only difference in Canada impoted car was Daytime running lites on all the time and Front and Rear Bumpers we higher crash test rating from US and Europe. July 1 2007 all changed to harmonize with USA. was a 2000.00 retrofit Fortunatly I imported after and saved the cost.
Have fun and check out all past infos. One thing that will keep you happy in cold weather is the TWO dots on the bottom of the REST button the right one when pushed on after you stop the car to go for a quick in and out is a 15 min auto off to keep the heat or air cond running. Battery charge is important but I think the manual says it will nit work if battery is low.
Welcome to Crossfire owners in Canada we are very few.
