Old Mar 17, 2009 | 07:13 AM
nate_man's Avatar
nate_man
Default Re: Hey what kind of wheel is this? I think this would look pretty awesome on an Xfire
Originally Posted by jonnyangel04
i had 19 by 8.5 in the front with a 30 mm offset and a 20 by 9.5 rear with a 35. if I had to do it again I would go 19x8.5 35 and 20x9.5 45. tire sizes is the problem dont go wider then a 30 up front and you should be fine
Well here is some additional info from tire rack that helps with the offset question:
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
