Old Mar 17, 2009 | 07:20 AM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: supercharger woes
  • Remove your NW intake, return to the stock intake system and go for some test runs while noting any difference in power. Try running against the stock SRT6 again because weather you have just a pulley or intake; you should always be in front.
  • If nothing changes then reinstall the NW intake and remove the C3 pulley, returning to the stock pulley. Again, note any difference in power and run against the stock SRT6 for comparison.
If your car was running normal stock, then maybe something went wrong with the install of aftermarket parts.
