Old Mar 17, 2009 | 02:10 PM
James1549
Default Re: Crossfire Spoiler completely vandalizied
Hey guys, no problem to answer the question.
But first I wish people would sign their postings so we know who we are talking to, -- user-names seem so impersonal when replying to a posting.
To remove and install a new wing assy is very easy and shouldn't take more than about 30 minutes. I saw a white one on ebay. Which could easily be taken apart and painted seperately.
Open hatch
Remove cap and screw from hatch trim pull handle.
Pull off lower section of trim using the pull handle.
Unplug 2 electrical connectors.
Remove Sixteen nuts with a 10mm socket.
Partially close hatch and gently work loose the wing assy and pry with only your fingers from the edges.
The wing assy may be stuck because of the gasket but it comes off with patients.
To install new wing assy, reverse proceedure being sure assy is centered before bolting in place. Also you may want to purchase a new strip of rubber gasket to prevent any water leakage. 1/4"X 1/4" self adhesive rubber weather stripping will work fine from a hardware store.
James
