Old Mar 18, 2009 | 06:08 PM
maxcichon's Avatar
maxcichon
Default Re: Crankshaft position sensor + warranty + diagnostic fee waived
Originally Posted by matthewson00
See thats what i thought as well. I figured that the fee was for those that bring their vehicles in for every little hiccup that turns out to be nothing, but this is a bona fide well known issue. I have 46k on it right now with a 8/80 "added care plus". I still feel like its going to be a long winded fight at the counter
I just read what's covered with the "Added Care Plus" here:
http://www.chrysler.com/en/service_c...les/index.html
  • Core Plugs
  • Cylinder Block and all Internal Parts
  • Cylinder Head Assemblies
  • Flywheel and Starter Ring Gear
  • Fuel Injection Pump (Diesel engines only)
  • Fuel Injectors (excluding clogged injectors)
  • Harmonic Balancer
  • Intake and Exhaust Manifolds
  • Oil Pan
  • Oil Pump
  • Seals and Gaskets for Listed Components
  • Serpentine Belt Tensioner
  • Supercharger
  • Timing Case, Chain, Gears, Belt and Sprockets
  • Turbocharger Housing and all Internal Parts
  • Turbocharger Waste Gate Actuator
  • Valve Covers
  • Water Pump and Housing
And:
  • All Wiring Harnesses
  • Body Computer
  • Body Control Module
  • Coil Pack Assembly
  • Distributor
  • Electronic Fuel Injection System (Excluding Clogged Injectors)
  • Engine Control Module
  • Factory Installed Radios and Speakers (Includes CD and Tape players)
  • Generator / Alternator
  • Horn and Horn Pad
  • Ignition Coil
  • Manually Operated Electrical Switches
  • Oil Pressure Sending Unit / Switch
  • Park Neutral Position Switch
  • Powertrain Control Module
  • Rear Window Wiper Motor
  • Single Module Engine Controller (SMEC)
  • Starter Motor and Solenoid
  • Temperature Sending Unit / Switch
  • Transmission Control Module
  • Voltage Regulator
  • Windshield Wiper Motor
  • Wiper Control Module
And how it's covered with a $100 deductible.
$100 Deductible
You pay only the first $100 of the total cost of covered component repairs performed during each visit. Added Care Plus pays the rest! Other deductibles may be available. Ask a trained specialist at 1-800-442-2666 for details.
There should be no arguing. Period.
