Thread: K&N Air Filter
Old Mar 19, 2009 | 10:45 AM
N.Y.XFIRE's Avatar
N.Y.XFIRE
Default Re: K&N Air Filter
Originally Posted by spensley
Hi Rob,
So if I purchase this filter to replace the one which came with your intake will I definately have to use the new bracket supplied?
Does this bracket just push the P/S line out of the way or is it completely relocating the P/S line (I can't see it in your pics)?
Any issues with engine temps etc due to the larger filter blocking the radiator?
I have a Limited.
Thanks.
A simple heat shield does work...have one on mine after driving for 60 miles i can grab the filter and not even tell the filter is sitting right next to the radiator its about 5 inches away from the motor and radiator....check out the shield neuspeed has on theres works great! might help on your heat situation (sorry you talking about engine temp just re-read)
