It is one bolt, E8 torx, to remove the Crank Position Sensor. The plug has a lock that faces the passenger side fender. Press the top of the lock and pull the connector off. Pull the bolt and dont drop it and then slide the sensor out. Install is reverse order. It is very easy. Good luck.
Make sure you do this with a cold engine.
MikeR
