Old Mar 20, 2009 | 02:20 PM
doc440's Avatar
doc440
Default Re: Your electronic knowledge put to a challenge!
Maybe the BCM is looking for the down limit switch to close and the up switch to open when you slow down. But I guess when I think about it, that would only be true if the system was in "automatic mode"- the BCM is not seeing the spoiler move to the down position and probably sets off the malfunction alarm. Did you perform your road tests after presing the switch on the dash to the "wing up" position?
