Old Mar 22, 2009 | 08:18 PM
onehundred80
Default Re: Cruise Control won't turn on!!
Originally Posted by all_Bran
2005 Crossfire Limited Roadster
I'm having an issue with the cruise control. Am I correct to assume that all you need to do to turn on cruise control is either move the lever up or down to SET it at the speed you're currently at? I did that, and it never SET. When I moved the lever UP to the ACCEL/SET position, and you could feel the car try to speed up (ACCEL). But it never locked in the speed.
The only thing I can think of is that I currently have my winter wheels/tires on which don't have pressure monitors. So technically the car thinks it has 4 flat tires, right?
Anybody seen this before? I have seen it work before, but havent' tried it in months. Any help would be greatly appreciated. Thanks!
Try the fuse first, #10 under the hood in the accessory box. It is always best to look for a simple solution first if not then the following is from the Repair Manual. By the look of it the problem get harder to solve.
'Control of the speed control system is accomplished by a
speed control switch (1) which is located just above the multifunction
switch (2). The speed control system also uses other
components of the vehicle to accomplish its tasks. The five
other major components used are as follows; The PCM, Accelerator
Pedal Position Sensor, Kickdown Simulator Switch,
Throttle Body and the Clutch Pedal Position Switch (Manual
Transmission). The speed control system is designed to operate
at speeds above 25 m.p.h. (40 km/h).'
Good luck.
