Tire guy says 35mm offset in rear OK. Is that right?
Mar 24, 2009 | 08:00 AM
permalink
BLKFIN
ADDICTED TO BOOST
May 2005
1,625
McKinney, TX
Re: Tire guy says 35mm offset in rear OK. Is that right?
Keep in mind that the difference between 20mm and 35mm is a fraction of an inch. The 35mm will fit, the wheel and tire will just be “tucked in” closer to the inner wheel well. The lower the number, the further out the rim is “pushed” from the mounting surface in most cases. I like the look of the wheel being pushed out myself, but if you go on Discount Tires website and pull up fitment for our cars, you will find 20mm, 25mm and 35mm. They all will fit, they just will fit differently. I hope this helps.
BLKFIN
View Public Profile
Send a private message to BLKFIN
Find all posts by BLKFIN
