Old Mar 24, 2009 | 11:20 AM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: 12V Power in Door for Tweeters
This is where the service manual is your friend. You can locate the schematics for the various door circuits and see if any of the wires are hot. I expect there are none.
If that is the case, you have to investigate whether or not the duct from the body to the door is hollow and just a path for wires or if there is an actual bulkhead seal that the existing wires pass through.
Also, sometimes, even if there is a true bulkhead seal, the factory may have an extra wire or two that are not used... you only need one as there are grounds everywhere.
Good luck!
