Old Mar 25, 2009 | 04:44 PM
all_Bran's Avatar
all_Bran
Default Re: Cruise Control won't turn on!!
Originally Posted by rcompart
I had this problem about 3 weeks ago. What worked for me was pull the positive on the battery cable for an hour and then when you start to use the cruise, start at a low speed and bump it up a mile an hour every few seconds or so until it quits. Then accelerate way above that and then back down to where you started and repeat until you get it to go all the way up to wherever you want the cruise to stay the highest. YMMV
Wow, that sounds quite confusing. And I couldn't get it to set at any speed. I think the lowest I tried was 55mph or so. Same thing, nothing. If I held it UP to the Accel position, you could feel it open up a bit and try to accel. But quickly returned to normal and never set the cruise.
Any other thoughts?
