Old Mar 26, 2009 | 07:20 AM
maxcichon's Avatar
maxcichon
Default Re: Cruise Control won't turn on!!
Note: A cable and a vacuum controlled servo are not
used. This is a servo-less system.
The above is straight from the Service Manual, no servo's used.
180,
I just can't let this pass. A servo is any electromechanical device that uses an external programming signal to control another device. Trust me, a vacuum motor while a servo, is not the only servo.
In your last post, you mentioned "the throttle body motor". That, too is a "servo".
Truely.
Back on topic:
And, after I poked aruond on mbworld, the question of tire sizes came up. Are yours OEM, or have you changed the sizes?
