Old Mar 26, 2009 | 01:46 PM
waldig's Avatar
waldig
Talking Re: 7th injector or larger injectors???
Jim I have to admit that I can not figure out how to go back and search my own posts. Look and you should see the one that I did with a simple hose from that manifold to the fuel pressure regulator and solved the problem with the a/f issue. Lean is caused by the loss of presure differential across the injector due to the higher cyclinder pressure with boost. IF I knew Id show you but it was in the last 2 months, and yes I have a finer tune capability that Iam working on with all the other issues like my Soviet suprise inthe electrical department coming up next month. Enjoy, Woody
