Old Mar 26, 2009 | 08:30 PM
mrwhit08's Avatar
mrwhit08
Default Re: Light out issue...
Is the Illumination Control Module along with the 21 pin connector the diagnostics sections references actually attached to the headlamp switch below/behind it as pictured in the "2004_Crossfire_Service_Manual.pdf" ..ummmm PDF page # 874???
Answer:the 21-pin is actually right behind the switch.. everything you need at least to hook the meter up to.
