Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Mar 29, 2009 | 08:26 AM
permalink
drhrsh
Jan 2005
56
Centennial, Colorado
re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
15.) At this point you need to decide if you want to "modify" the assembly which means inactivating the locking pin or buy a new assembly. I bought a new one for $379.00.
16.) The assembly process is basically the reverse of removal but I did learn a few tips. The new assembly comes without the key warning sensor so you need to save and reuse the old one. It has a small locking pin making it difficult to slide out. I tried to lift the pin and slide it out with no success. Then I realized I didn't need to save the old assembly so I used a Dremel tool to cut the old housing and lift the assembly out. Then it slid into the new housing easily.
drhrsh
View Public Profile
Find all posts by drhrsh
