Old Mar 29, 2009 | 01:23 PM
faiz23's Avatar
faiz23
Default Re: deadening car to reduce road noise
Originally Posted by distantpulse
I just purchased a bulk package of dynamat extreme to use in the trunk area. Not sure how much different this is to what you have. Supposedly, this is the best stuff to use for deading sound. I have yet to install it, but I bought it because I recently did the exhaust and it is pretty loud. Sounds great, but on the highway im getting some drone around 70-75mph. So.....when I finish, I will take some pics and give you my opinion on the difference.
dynamat extreme is good stuff but they rape you for price,
do your research and
http://www.sounddeadenershowdown.com/products/
Dyna mat extreme bulk pack $140 for 36 sq ft $3.88 per ft
Published Thickness (mils) 67
Published Foil Thickness (mils) 4
Raamat 60sqft for $130 $2.16 per ft
Published Thickness (mils) 60
Published Foil Thickness (mils) 2
damplifier 40sq ft for $115 $2.87 per ft
Published Thickness (mils) 65
Published Foil Thickness (mils) 3
damplifier pro 20sq ft $105 $5.25
Published Thickness (mils) 80
you can get damplifier which is better product for less.
now keep in mind there is a difference between how thick it is and how much weight it is. you want to mass load and add weight. raamat is cheaper but has 25% more airbubbles so less weight but thicker due to added air.
ALWAYS BUY BUTYL BASED NOT ASPHALT
