Old Mar 29, 2009 | 02:35 PM
No Warning Shot's Avatar
No Warning Shot
Default Re: HELP! Transmission Fluid?
Originally Posted by howvood
The leak is probably the "O" ring in the electrical connector. The transmission fluid is Shell 3403 which you may find at a Shell Distributor or you can stop at any Mercedes dealer or possibly at a Chrysler dealer and buy it. It is a unique ATF so don't put just anything in it. There is no dipstick because the level is critical and, in addition to the dipstick tool, something is needed to measure the trans temperature when you fill it. I use an infrared thermometer that I aim at the oil pan but the dealers, I was told, plug the car into their computer and it tells them the temp. I don't recommend fooling with the transmission unless you have a lot of extra cash to cover your errors!
What I don't understand is that if the level is so critical, wouldn't you rather be able to check it and make sure it's not low? One thing I don't understand about new German cars is that they don't even give you a dipstick to check the oil. Don't you think that some people would want to be able to SEE how their oil or transmission fluid looks as they check it? I sure like to see it to make sure something bad isn't going on in there.
Wouldn't you think the required temp to check the transmission fluid pretty much be normal operating temp like any normal car anyways?
