I just talked to the tech that is responsible for Crossfires at my dealership about the radio display problem. First, he was aware of the problem. Second, he was not aware that a TSB may be forthcoming to fix it. He did volunteer to call me when he was notified. He indicated, if it is going to happen, Chrysler is usually slow in getting this stuff out.
Then I asked him about adding a multi-disc CD player to the existing system. I suggested locating it in the "hole" in the trunk made available for Euro first-aid kits.
He thought it could be done. However, you need to remove t he radio which he said is more difficult than the more typical system. He indicated that there are two latch points. And that you have to be careful when manipulating these to release or unscrew the unit. In addition, he said that there is very little room behind & around the unit inside the dash which would limit the space for a CD changer adapter or a larger replacement unit.
I don't know how accurate or applicable all this is. But I thought I'd pass it along.
