Old Mar 29, 2009 | 06:12 PM
j-fire's Avatar
j-fire
Default Re: Thinking coilovers
Originally Posted by velociabstract
The main reason I'm looking at the Bilstein is the adjustability. I want something that will ride acceptable on the street. The roads in P.R. are mostly horrible. The entrances and exits to parking lots or driveways all have sharp angles or deep crevices. I need to have the car close to stock height to get to the track and then lower it once it get there. I still need to do some intell on the Bilstein. If it wont work for me I'll do what most do. Lowering springs and good shocks and leave it at that.
Les
well Les, then the koni adjustables with either H&R or eibach will work. very nice ride. i say better than stock. at least in my case. the koni's are quite easily adjusted, and can suit just about any ride needed. the car will still not handle as well as many sports cars out there, but it is improved, and can be adjusted to be quite 'cushy.' even TOO CUSHY if you set it too soft. (it will feel like the backseat of your grandmas buick that you got seasick in as a child!!!!!)
