Old Mar 29, 2009 | 08:39 PM
onehundred80
Default Re: deadening car to reduce road noise
Originally Posted by faiz23
i checked the holes for drainage under the door panel they have rubber grommets and i popped them off and it is still open so it is not covered. is there an open hole that water flows through that i need to check or is it the 4 or 5 holes on the bottom part of the door.
The drain holes are not the ones with the plugs in, the drains are the ones in the bottom front and rear of the door, they are just small oblong slits in the thinner part of the door.
