Old Apr 1, 2009 | 11:14 AM
  #54 (permalink)
cruzinquick's Avatar
cruzinquick
Default Re: 178/181/185 pulley comparison
Originally Posted by XXxx_Totmacher_xxXX
first yes you can't compare ET, but you can reasonably compare MPH from track to track. Whats with the 5mph kick on the 181 comparo? 5mph is alot in the way of horsepower.
Also Someone should go back drag times / myslips and compare all there back 1/8 times. subtract the 1/8 mile et/mph from the 1/4 et/mph to see what the car "picked up" in the back 1/2. I think it's safe to say that the back half is almost all car and not driver. that way you can do a comparo factoring out the driver.
I've said it before, I think it's ALL in the tune. I'm sure the timing on the tunes the larger pulley's are seeing is basement level. Add to it the ecu is probably pulling out more timing because of charge air temps. I'll bet almost anything a 185+Sunoco+more timing would be the answer for some smack down times. My statement is further backed by the substantial gains these N20 cars see. the N20 cools the Charge air to the point the ecu starts adding timing back in to complament the larger pulley.
Stop chasing boost, 1 degree of timing is worth way more then a pound of boost...
You can't compare track to track mph. Too many factors in between. My best mph is not my best time, i.e. tire spin... I only say it 20 times a day. DA is the only balancer of how your run can be compared to someone else. Regardless of mods, what you run and when you run it ,all comes down to DA. Even the NHRA struggles in Denver
