Old Apr 1, 2009 | 06:32 PM
  #265 (permalink)
Mad_Med05X's Avatar
Mad_Med05X
Default Re: V8 Crossfire Conversion Diary
I talked to a guy at an audio store and he said that if you installed an automatic start on you car, you could By pass alot of the electrical stuff! He said you will need the electronic key from the donor car, the ECU, and the wiring harnes. He said the code on the electronic key will be used to auto start the car, therefore by passing your stock ignitiion. He has done this by pass on many top line project cars and save money when dealing with the electrnics! The only down fall is that you will only be able to auto start you car.
Have anyone else heard of this type of Electronic by pass.
