Re: Piggyback's
posted for later reference.
POWERTRAIN CONTROL MODULE C2 - BLACK 24 WAY CAV CIRCUIT FUNCTION
1 - -
2 - -
3 - -
4 - -
5 - -
6 - -
7 20GY/WT (EXCEPT SRT) EGR SOLENOID CONTROL
8 - -
9 18BL/WT (SRT) GENERATOR CONTROL
10 - -
11 - -
12 18VT/WT COIL ON PLUG DRIVER NO. 5
13 20GY/BR AIR PUMP SWITCHOVER SOLENOID CONTROL
14 20DG/VT (EXCEPT SRT) SHORT RUNNER VALVE SOLENOID CONTROL
15 18BR/GY (EXCEPT SRT) OXYGEN SENSOR 1/1 HEATER CONTROL
15 18BR/BK (SRT) OXYGEN SENSOR 1/1 HEATER CONTROL
16 - -
17 - -
18 18GY/VT FUEL INJECTOR NO. 6 CONTROL
19 18GY/DG FUEL INJECTOR NO. 3 CONTROL
20 - -
21 18GY/YL FUEL INJECTOR NO. 5 CONTROL
22 18GY/RD FUEL INJECTOR NO. 2 CONTROL
23 - -
24 18BR/BK (EXCEPT SRT) OXYGEN SENSOR 2/1 HEATER CONTROL
24 18BR/GY (SRT) OXYGEN SENSOR 2/1 HEATER CONTROL
Powertrain Control Module C3 - Black 52 Way Cav Circuit Function
1 - -
2 20pk Camshaft Position Sensor Signal
3 20bk Sensor Ground
4 20vt Right Knock Sensor Signal
5 20dg/rd Engine Coolant Temperature Sensor Signal
6 20dg Sensor Ground
7 20bk Oxygen Sensor 1/1 Signal
8 20yl/dg Iat Sensor Signal
9 20br/dg Sensor Ground
10 20rd/dg (except Srt) Map Sensor Signal
10 20rd/bk (srt) Map Sensor Signal
11 20yl/wt (except Srt) Maf Sensor Signal
12 20br (except Srt) Sensor Ground
13 20dg/wt Crankshaft Position Sensor Signal 1
14 - -
15 20gy/bl Oil Sensor Signal
16 20bk Sensor Ground
17 20yl Left Knock Sensor Signal
18 - -
19 20gy Sensor Ground
20 20wt Throttle Position Sensor Signal 2
21 20yl Throttle Position Sensor Signal 1
22 20vt 5 Volt Supply
23 20bk (except Srt) Oxygen Sensor 2/1 Signal
23 20bk/br (srt) Oxygen Sensor 2/1 Signal
24 - -
25 20br/yl (except Srt) 5 Volt Supply
26 20dg Crankshaft Position Sensor Signal 2
27 18gy/bk Fuel Injector No. 1 Control
28 18gy/bl Fuel Injector No. 4 Control
29 - -
30 - -
31 - -
32 - -
33 - -
34 - -
35 - -
36 - -
37 - -
38 - -
39 20rd/yl 5 Volt Supply
40 - -
41 - -
42 - -
43 - -
44 18gy Coil On Plug Driver No. 6
45 18dg Coil On Plug Driver No. 3
46 18bl Coil On Plug Driver No. 4
47 18bk Coil On Plug Driver No. 1
48 - -
49 18vt Coil On Plug Driver No. 5
50 18yl Coil On Plug Driver No. 2
51 - -
52 - -
