Thread: Piggyback's
Old Apr 2, 2009 | 01:14 PM
XXxx_Totmacher_xxXX's Avatar
XXxx_Totmacher_xxXX
Default Re: Piggyback's
The Camshaft Position Sensor is a hall effect type sensor (3 wire). The Camshaft Position Sensor is mounted on the front of the right cylinder head.
The Crankshaft Position Sensor is an inductive type sensor (2 wire). The Crankshaft Sensor is used to determine the crankshaft position and speed. The Crankshaft Position Sensor is mounted on the left rear of the cylinder block.
