Originally Posted by cruzinquick
Without seeing your mods, I have to assume you don't have a NW CAI? Still great AFR's and probably the best with the 185. Brian is the only other one in 11's(AFR's), but not sure what he recorded in TX. My point about the NW CAI is your not seeing max boost from your 185. If you do have one, then your farther along than most on here. Share your tuning or datalogs. I assume your datalogging if you know your afr's at those rpm ranges.
This is my friends car. Lars. Known as StarCar on this forum.
We both have SLK32. Same setup. Except, he has schrick cams and i
Kleemann´s cams. DIY NW style intake. ( different intake pressure 0,24 bar,
3,48 PSI, between SL55 Y-pipe and green filter, in my car ) Inside 3´
Cooling system separated. Johnson 30 pump.
LET 185 mm pulley, Feritta Race system, with two - 100 cells cats.
World biggest HE. Bigger than Needswing new Super HE.Cooling down in 10 sek, when you let of the trottel. Back to crousing temp.
First day at tuning both hit MAP sensor limit. Day three everything was fixt
by a German fellow, T.M. Chiptuning. Dont know how he fixt all problem.
No limp mode or nothing. Intake pressure 21 - 22 psi. Before we hit the MAP sensor limit all day.
Now the car is running as he...
We tried to Dyno Lars car but there was to mutch slip on the tires.
The only thing we checked was the AFR. And there where no problem.
11,7 AFR. My car is between 11,6 - 11,7 - 6400 rpm. RPM Limit is from Kleemann.
Next run is in May. With Needswings intake manifold and VRP Headers.
And Hoosier tires. Interesting.
By the way. My car is faster than he's
This is going to be big fun.
/Göran
