Old Apr 3, 2009 | 02:20 PM
  #90 (permalink)
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Texas Mile 2008 March 28-30th
Originally Posted by SLK32Germany
Brian,I also did your IC-Cirquit Separation and I saw on pictures that you put aluminum foil around your IC. When I have my SC off the car, I will decide if I do the same as you did or if I only put a aluminum foil into the Cylinder-V to keep the heat from the engine-block away from the IC. Some people told me maybe this would work better than cover the whole IC with aluminum foil? What's your opinion about this?
Thanks.
I used this alumina heat shield I got as a sample - That's the big white roll you see in the picture. They use it in metal foundries as a heat insulator. I used high-temp metal foil to keep it secured around the HE.
If you want, I can send you some - I have a ton left over.
