Thread: Piggyback's
Old Apr 6, 2009 | 10:06 AM
XXxx_Totmacher_xxXX's Avatar
XXxx_Totmacher_xxXX
Default Re: Piggyback's
okay did my homework, that is exactly that, a MAP clamp, but you would want there VC2-5 i believe as I'm pretty sure outr MAP sensor is a 5 volt output. here is there discription on it. Read that then compare to what I posted above...
"Description
The VC2 Voltage Clamp is designed to condition the output of voltage based air flow meters, MAP sensors and mass air flow sensors. It is often used to avoid fuel cut in forced induction applications. Under normal operating conditions, the VC2 outputs a signal that is identical to the signal present at its input. When the voltage of the flow signal reaches the internally set clamp level, the VC2 maintains a constant output voltage at the clamp level as the input voltage rises. The VC2 differs from the VC1 by offering a hard clamp function that is user adjustable. The hard clamp allows the output to track the input right up to the clamp voltage. Once in clamp, the VC2 maintains the clamp level with high accuracy regardless of overdrive."
