Re: induction kit
Well, I just reconfigured my dual system, that makes it a lot easier to work with the mass air flow senser. I now have it inline with the my tubing. I also tried something a little different, and boy did it respond. I'm running only one air cone, with a special heat shield that you can hook a hose up to, from an air scoop. (Which I also made) I'm not really running the scoop just yet, because I'm still working out some space issues. Any way I'm running one air filter on one tube, and the other tube, I have running into the original ram air inlet. Wow, now thats some ram air! I did place a high density , high flow piece of foam inside the non-filter having tube. Along with some fine mesh to catch any passing debris, it works really well. I'll post a rendering or something for all you to see.
