Old Apr 8, 2009 | 08:29 AM
Hands's Avatar
Hands
Default Re: speed booster a must read
Originally Posted by PAULW
If you will read just a few of the replies about the Sprint Booster (just do a shearch on sprint booster) you will find 99 out of 100 love it and will say it is the best mod they have done. Keep this in mind "it CORRECTS THROTTLE LAG ONLY, IT DOES NOT INCREASE HP!" and it works. Another thing it does not just move the TPS to an early WOT, WOT has nothing to do with it. Buy one, you will like it.
Maybe your seeing different numbers than i do when you are scoping and charting what its doing
It doesnt change what you call throttle lag at all... Thats the amount of time it takes for the pedal ,ecm, and throttle actuator to respond to eachother. it does change pedal travel thats all
Something tells me i might should not have posted what i found. But its what i found... I did post a better explanation of what i found in the best 300 mod. And i did alittle more than just read
So i will bow out
Thanks
Mike and Kathy
