Old Apr 8, 2009 | 11:51 AM
XXxx_Totmacher_xxXX's Avatar
XXxx_Totmacher_xxXX
Default Re: More boost more power?
The more boost the ECU sees the less the timing it will advance. The higher the Charge Air Temp the less timing it will advance. Both work conterproductivly with a larger pully from a factory tune perspective. Yes the car makes more boost and yes it will make more power (good rule of thumb would be 7-12hp per psi boost) but at the same time your going to lose power by running less timing. So in the case of a factory tune I could see where the power lost by the reduced timing is larger then the power gained by the increased manifold pressure.
The trick is to win in both worlds.
