Old Apr 8, 2009 | 12:24 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: More boost more power?
Originally Posted by XXxx_Totmacher_xxXX
The more boost the ECU sees the less the timing it will advance. The higher the Charge Air Temp the less timing it will advance. Both work conterproductivly with a larger pully from a factory tune perspective. Yes the car makes more boost and yes it will make more power (good rule of thumb would be 7-12hp per psi boost) but at the same time your going to lose power by running less timing. So in the case of a factory tune I could see where the power lost by the reduced timing is larger then the power gained by the increased manifold pressure.
The trick is to win in both worlds.
At what point does the ECU begin to pull timing? Boost levels, IAT, ECT, etc..
It's one thing to talk about it - another thing to know....
Remember, the 185mm only overdrives the SC 4% more then a 178 at any engine RPM. (see post #6) So these claims don't really add up.
I do agree that increased IAT (and ECT) will cause the ECU to pull timing - but that can happen to a factory setup on a hot day. (or pump failure, clogged/leaking HE or IC....)
I found that separating the coolant systems, installing a larger HE and adding a larger flow tank for the IC coolant reduced my IAT with the 185 pulley below what I was logging when stock.
