Old Apr 8, 2009 | 05:16 PM
Bulldogger's Avatar
Bulldogger
Default Re: Answer to 185 pulley
Originally Posted by carpen04
look i hear some people say that the 185 is more boost which is true but it is not putting the numbers on the board like it should. ok i am going to throw this at you guys and you tell me if i am on the right track.
two big reasons why you are not putting numbers on the board is because lose of traction which can be corrected with a good set of tires. but my main reason is the HEAT PROBLEM. the heat saps the horses right out of our cars and heat in our cars is bad...
my question is could you fix that by not getting into the INTERCOOLER which is alot of work but a cheaper and more efficient way would be replacing the H\E (for those who are confused the intercooler is under the S\C and the H\E is in front of the engine bay.) With that said, the more cheaper way would be to purchase the Needswings upgrades H\E and for kicks put a johnson pump for faster flow...and to top it off we all know how water is a better cooler then our coolant\antifreeze...fill our big needswings H\E with water with the johnson pump..
I think that will take care of the heat problems also it won't burn a hole in our pockets.
so what do you think guys does it sound good or no..i dont know alot about cars but it sounds like a good idea, for me if i upgrade from my code3 to get a 185 i would run this system..
You're also forgetting about the fueling problems like running lean.
