I just fixed it up for Hands
Being that i didnt test the SB on a manual but im sure that the SB is not doing anything for lag time. If you graph a OME and the SB on throttle curve and over lay the graphs you will see no difference, from a snap throttle, a snap WOT, or a part throttle, it does nothing for lag what so ever.
Explain how the graph was able to test foot pressure applied to the pedal.
I'm curious how that was done.
It is obvious that many who dismiss the SB haven't actually tested one side by side.
I don't care what the graph says. I can tell the difference and it is dramatic.
And I have tested, side by side one NA with and one NA without.
Both were manuals.
Both had fresh throttle resets.
roadster with a stick
