Re: Piggyback's
Brian- Maybe tot, md, insert name here, can afford replace a motor from testing. As you know there are more followers on here,(myself included), than leaders. So are you saying that until someone damages a motor any mod is safe to recommend? What about Rman's SC melting? Wasn't that with a 181 only?
I like Waldig's method of testing. Does it first, post results, then risk factor or worthiness.
Again your the only 185 with positive results on a srt6. Your SI tune may have something to do with it. Did you datalog on your mile runs recently in texas? If so can you post your AFR chart for the run?
