Originally Posted by Panthro
Is the car jacked up? Sorry I had to ask. If it is, the wheel should just be sitting on a rounded protrusion and after you remove the 5 bolts the wheel should come straght off. If you are having problems, try grabbing the wheel by the spokes close to the center and lift slightly and pull twords yourself.
Yeah it was off the ground. A swift couple of kicks took care of it. Thanks guys
