Old Apr 12, 2009 | 08:26 AM
maxcichon's Avatar
maxcichon
Default Re: Problems with putting top up ?
Originally Posted by nekers
thanks - so when you push the button to put the top up - does the back lock in first before you lock in the front - the back isn't locking in.,.
While holding the button down, the rear should close AND LATCH on it's own. You will hear a beep. Release the button.
Then, using two hands, use the right to turn the handle 90 degrees. Use the left to slowly ease the front down to touch (don't slam it) and turn the handle to lock.
It SHOULD be that easy-if it isn't, there might be a problem.
