When I had mine in at the Dealers last month for an oil change I handed them the TSB for the transmission leak. They checked it out and told me no leak per TSB however my driver side valve cover did have a small leak and they will order the gasket. While it was on the hoist, I also had them check the steering damper. I was told the damper is OK however the right tie rod is marginal so they have also ordered and will replace when they do the gasket. Service Manger says it's all covered by warranty and he will even do an alignment N/C!
