Re: 6000k Halogens
guys not sure why people are saying that driver side mounting is hard that was the easiest plus you have so much space to work with.
the passenger side has the overflow tank that needs to me removed so you can install the bulb and mount ballast. i didn't need to remove the anything on the driver side just make a mounting plate.
i will take pics and post tonight.
my kit came with spade terminals that i just plugged into the stock h7 plug. the wires are already fused at 15 amp on each side which is good for hid and i believe it is a 16 gauge wire.
i normally recommend running your own harness to the battery direct using 12 gauge or 14 gauge wire.
once my retro is done i am gonna fab up a harness for both low beam and fog in HID.
