Code:
by patpu;
have any of you that have lowered your cars had the alignment adjusted afterwards?
Hi Pat,
I can't speak for others but I did need to have my alignment done after the H&R Sports were installed. I also had to get a KMAC kit because the shop could not adjust the camber back anywhere close to stock settings.
In fact I think I have pictures somewhere I took of the rears sitting on the ground where the outer edges of both tires were not making contact at all before the KMAC was installed. I know the H & R Sports are lower than the Eibach's so maybe that is why I needed the alignment?
Right now I have the stock wheels on without spacers until the weather improves for sure. Hope this helps.
Stay safe...
Respectfully,
Paul (MisterTaz)
