Originally Posted by themush1326
My tire appears to have a slow leak and I'm pretty sure its comming from the valve stem.
Its happen with both my snow and normal tires and is limited to just one.
When put air in there is a slight his after I remove the air hose and i can feel a little bit of air come out and it stops after a few seconds.
If the valve needs relpacing is it all once piece with the TPMS?
I had the same issue with my drag radials, I bought the valve core tool for $1.86 at advance auto and tightened them up and that solved the issue.
