Old Apr 16, 2009 | 02:58 PM
05LtdRoadster's Avatar
05LtdRoadster
Default Re: Problems with putting top up ?
I had the same problem with mine, the adjustment is VERY easy to do yourself and will save you time and money. All you need to do is adjust the latch on the rear of the convertible top UP. When you are opening the top, stop it in the position before the tonneau cover opens. It only takes a minute to fix so don't worry about the top releasing the hydraulic pressure. Check the latch to see if it is lined up straight and towards the uppermost position. Mine was kind of crooked in place, after I loosened the bolts on both sides, straightened the latch, moved it upwards, and re-tightened the bolts, the top is closing properly just like the manual says. With the right tool, its an easy DIY fix!
