Originally Posted by kurtisberry
So I have read the white paper and the SB is nothing more than a linear amplifier with 1.428 gain. There is no nonlinear part of the equation. It produces a signal of 100% throttle to the ECU at 70% throttle position. 100/70 = 1.428. There is no change above 70% throttle position.
I spent a few minutes this morning and designed my version of the SB. When I have a chance (trout season opens this weekend), I will build, install, test and post drawing, pictures and instructions, if it works or doesn't.
I haven't looked into sourcing the connectors, so I will probably hard wire the prototype. If any one has info on the connectors, I would appreciate any help. With the connectors I could build a nice plug in unit like the SB.
I chose a fairly expensive dual op-amp ($7) so I'm looking at around $12 in parts without connectors.
Kurt
