You might be able to cheaply integrate your prototype into the actual foot pedal assembly without the need for connectors. It's easy to remove and not to expensive to replace.
I would humbly suggest that you use two op amps in your design. That way if one IC or circuit failed, the other circuit would still supply the ECU with a throttle position signal. The SB is a single-point-of-failure device.
Also, if you can vary the gain with a three position resistor or a variable resistor - that would be sweet. Say 1.2, 1.35 and 1.5.
Good luck...
